The CODESYS Modbus TCP Server SL is not compatible with application-based licenses.
The CODESYS Modbus TCP Server enables a controller to act as a Modbus TCP Server that is programmable with the CODESYS Development System.
2303000020
€50.00
The CODESYS Modbus TCP Server enables a CODESYS-capable controller to register as a Modbus TCP Server in a Modbus network. For CODESYS-compatible controllers can use this functionality, they require a COM port for communication. The CODESYS Modbus TCP Server product integrates this functionality seamlessly into the existing controller. During project engineering, the Modbus TCP Server is included in the device tree of an IEC 61131-3 project. Then configuration is performed directly in the development environment.
  • CODESYS Control runtime system on the device with SysSocket component
  • Available Ethernet adapter on the device
