CODESYS LicenseServer for Linux SL
Licensing made easy - CODESYS License Server for Linux allows users to set up a network license server on Linux devices and apply licenses via a web-based management tool.
The CODESYS LicenseServer for Linux package allows you to conveniently set up a license server on a Linux-based device and apply licenses to it. The network license server can be used to centrally license CODESYS controllers in the entire network.
Deployment is carried out conveniently via the CODESYS Development System. A network-compatible version of Wibu Codemeter Runtime is installed on the target system. In order to be able to use the network license server, a plugin for Redhat Cockpit is also supplied, which allows users to activate application-based licenses on the server via a browser.
Engineering | CODESYS Development System V3.5.20.10 or higher |
Runtime | All CODESYS Control runtime systems that support network licenses:
Runtime systems that use CodeMeter Embedded are not supported. This applies to the device-specific CODESYS Control SL products (for example CODESYS Control for Raspberry Pi SL or for PFC200 SL). |
Supported Platforms | Debian Linux |
Additional Requirements | |
Restrictions | None |
Licensing | No license is required. |
| Further information about our releases can be found at: CODESYS Releases & Teaser Notes |
