Company Holidays: December 22, 2025 – January 5, 2026
CODESYS J1939 Manager SL
The CODESYS J1939 Manager SL enables a controller to act as a J1939 ECU that is programmable with the CODESYS Development System.
2303000022
€100.00
CODESYS J1939 SL implements J1939 functionality on a CODESYS controller and enables receiving and sending of parameter groups. The fieldbus stack can be downloaded dynamically together with the IEC application. CODESYS J1939 editor pages offer an easy way to parameterize the J1939 communication.
CODESYS Control V3
CODESYS Control runtime system on the device with component “CmpCAACanL2”
