CODESYS IO-Link SL
CODESYS IO-Link SL allows CODESYS users to easily integrate IO-Link devices into CODESYS projects.
2303000008
€150.00
CODESYS IO-Link SL enables the integration of IO-Link devices into CODESYS projects with EtherCAT and PROFINET bus systems. IO-Link sensors are recognized in the device scan and can be imported directly into the project. Configurators for parameterizing IO-Link devices are provided. The parameters of the IO-Link devices are stored in the CODESYS project. The data of the IO-Link sensors/actuators is processed with the information from the *IODD.xml files.
  • CODESYS EtherCAT Master or CODESYS PROFINET Controller
  • WIBU Codemeter support
  • EtherCAT_IO-Link Terminal EL/EP6224, EP6228 (Beckhoff)
  • EtherCAT_IO-Link Terminal AL1030, AL133x, AL1930, AL143x (IFM)
  • EtherCAT_IO-Link Terminal CPX-AP-I-4IOL,CPX-AP-A-4IOL (Festo)
  • EtherCAT_IO-Link Terminal BNI XG1, XG3, XG5 (Balluf)
  • EtherCAT_IO-Link Terminal MVK Pro (Murrelektronik)
  • EtherCAT_IO-Link Terminal SIG 300 (Sick)
  • EtherCAT_IO-Link Terminal XI510004 (Bosch Rexroth)
  • PROFINET IO-Link Master
  • Optional: CODESYS Key
