CODESYS HMI SL
This product allows for the creation of operating interfaces with CODESYS visualization for an HMI device (PC or panel), with data from CODESYS V2, CODESYS V3 and OPC UA controllers. The visualization is created with the CODESYS Development System (V3), the free IEC 61131-3 development system with a full-fledged visualization editor.
3.5.22.40
2304000009
From €440.00
CODESYS HMI SL is a software package that is installed on a remote computer to equip it with a graphical user interface (HMI). This new HMI support allows it to combine and visualize the data of one or more CODESYS V2 and CODESYS V3 controllers (data sources) on one remote HMI device. Since CODESYS V3.5 SP17 controllers with an OPC UA Server can also be visualized. A new datasource with OPC UA Client functionality is provided. The HMI SL can also be operated in conjunction with redundancy. An additional redudancy license is required for this.
Benefits
  • Integrated into the CODESYS Development System – for development of the remote HMI
  • Development in one project, either independently or with the PLC application
  • Scalable projects by unlocking any number of available data points
  • Simplified creation of the application by guided project configuration
  • Automated display of all available data in the controller network
  • Display of all functions and elements that are available with CODESYS Visualization, for example:
    • Alarm management
    • Trace and trend display
    • User management
    • Recipe management
    • Visualization styles
  • Download the visualization directly from the development environment to the HMI device
CODESYS Development System V3.5.17.20 or higher
Executable under Windows 10 / 11 / Embedded (32 / 64 Bit)
Since CODESYS HMI V3.5.17.0 the overlay feature is available for the TargetVisu. For the overlay feature a Windows 10/64Bit system is required.
Runtime with Datasource Manager
Includes the following Security fixes: 2026-11, 2026-12
30.09.2026
- 23.07.2026
20.05.2026
- 02.04.2026
Includes the following Security fixes: 2026-02
24.03.2026
- 22.04.2026
01.12.2025
- 25.09.2025
Includes the following Security fixes: 2025-07
04.08.2025
- 26.05.2025
- 18.03.2025
- 21.05.2026
- 22.04.2025
- 23.01.2025
- 20.11.2024
23.09.2024
- 31.07.2024
Includes the following Security fixes: 2024-02, 2024-03
04.06.2024
- 19.03.2024
- 02.05.2024
- 06.02.2024
- 04.12.2023
- 23.10.2023
05.10.2023
03.08.2023
- 01.06.2023
08.03.2023
31.10.2023
04.05.2023
13.12.2022
06.10.2022
03.06.2022
Includes the following Security fixes: 2021-09, 2021-11, 2022-02, 2022-04, 2022-06, 2022-07
06.04.2022
- 02.02.2023
- 28.10.2022
- 10.06.2022
- 25.01.2022
02.11.2021
23.07.2021
- 27.07.2022
- 18.11.2021
- 18.08.2021
26.05.2021
28.01.2021
19.11.2020
Includes the following Security fixes: 2020-05
19.09.2019
Includes the following Security fixes: 2019-01, 2019-04, 2019-06
23.08.2019
- 18.04.2019
20.02.2019
17.12.2018
16.05.2019
18.01.2019
23.10.2018
23.08.2018
For more details see:
10.07.2018
13.11.2018
17.07.2018
24.05.2018
27.04.2018
15.03.2018
26.02.2018
- 20.12.2017
20.04.2018
16.02.2018
- 17.11.2017
- 17.10.2017
- 21.09.2017
- 22.08.2017
- 14.07.2017
- 20.09.2017
- 23.08.2017
- 17.07.2017
- 22.05.2017
- 21.04.2017
- 16.03.2017
- 14.02.2017
- 15.12.2016
- 18.02.2026
