CODESYS DNP3 SL
Enables communication using the DNP3 protocol in CODESYS applications. A CODESYS PLC can be configured and used as an outstation or master.
The update to version 2.0.0.0 requires adjustments to CODESYS projects. Furthermore, boot projects created with DNP3 1.0.0.0 are not compatible with CODESYS PLCs that implement DNP3 2.0.0.0.
2303000025
€200.00
The CODESYS DNP3 extension consists of a CODESYS library that provides IEC function blocks for communication using the DNP3 protocol. The CODESYS DNP3 library provides function blocks to implement an outstation as well as a master.
CODESYS Development System Version 3.5.21.0 or higher
CODESYS Control for Linux SL V4.19.0.0 or higher CODESYS Control Version 3.5.21.0 or higher, CmpDNP3 required
Note: In demo mode, the software runs for 30 minutes without a license. After that, a manual restart is required.
CODESYS Key
