CODESYS Control RTE SL (for Beckhoff CX)
3.5.22.40
2302000001-SW
The product CODESYS Control RTE SL is a real-time software PLC for PC-based industrial controllers under Windows. The runtime system has its own real time kernel: deterministic behavior with jitter values in the µs region without additional hardware components or operating system extensions.
Interfaces
  • CODESYS OPC UA Server
The following CAN-PCI cards are supported:
  • Peak PCI: PCIe, MiniPCIe
  • Ixxat: SJA1000 (PCI card)
  • Automata: all PCI cards (1- and 2-channel)
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS J1939
  • CODESYS PROFIBUS Master
  • CODESYS Sercos III Master
Product options
The product can be extended by the following chargeable options:
  • CODESYS SoftMotion SL
  • CODESYS WebVisu SL
  • CODESYS TargetVisu SL
Minimum CODESYS Development System V3.5 SP19 Patch 1 (recommended V3.5 SP20 or higher)
Minimum CODESYS Control RTE SL V3.5 SP19 Patch 1 or higher
Supported Windows Versions: Windows 10 / 11 / IoT Enterprise 32Bit or 64 Bit, with Multicore-CPUs
Installation of CODESYS Control RTE SL
Hyperthreading is not supported a and must be deactivated
  • Peak PCI: PCIe, MiniPCIe (SJA1000-based)
  • Automata: all PCI cards (1 and 2 channel)
  • Innodisk: PCIe CAN adapter
  • HMS: passive CAN cards
The following Ethernet chipsets are supported:
  • Realtek
  • Intel (Pro1000 compatible)
  • Intel i210/i225/i226 (2,5G)
Following Hilscher hardware is supported:
  • PROFINET Controller: Hilscher CIFX or netX 100/500 controller with firmware 3.x
Efficency Cores (e-cores) are not supported and must be deactived
The size and functional scope of the IEC application are licensed. See the table of license tiers in the technical description.
The license is activated on a software-based license container (soft container) permanently linked to the controller, or stored on a CODESYS Key (USB dongle) for portable licensing.
Note: Without a license, the software runs in demo mode for two hours. After that, a manual restart is required.
Version .zip with packed Setup.exe (32 and 64 bit) .zip with unpacked Setup (32 and 64 bit) Release Notes Release Date
3.5.22.40
30.09.2026
3.5.22.30 - 23.07.2026
3.5.22.20
20.05.2026
3.5.22.10 - 02.04.2026
3.5.22.0
24.03.2026
3.5.21.60 - 22.04.2026
3.5.21.40
01.12.2025
3.5.21.30 - 25.09.2025
3.5.21.20
Includes the following Security fixes: 2025-07, 2025-08
04.08.2025
3.5.21.10 - 26.05.2025
3.5.21.0 - 18.03.2025
3.5.20.60 - 22.04.2025
3.5.20.50 - 23.01.2025
3.5.20.40 - 20.11.2024
3.5.20.30
23.09.2024
3.5.20.20 - 31.07.2024
3.5.20.10
04.06.2024
3.5.20.0 - 19.03.2024
3.5.19.70 - 02.05.2024
3.5.19.60 - 06.02.2024
3.5.19.50 - 04.12.2023
3.5.19.40 - 23.10.2023
3.5.19.30
05.10.2023
3.5.19.20
03.08.2023
3.5.19.10 - 01.06.2023
3.5.19.0
08.03.2023
3.5.18.60
31.10.2023
3.5.18.50
04.05.2023
3.5.18.40
13.12.2022
3.5.18.30
06.10.2022
3.5.18.20
03.06.2022
3.5.18.0
Includes the following Security fixes: 2021-09, 2021-11, 2022-02, 2022-03, 2022-04, 2022-05, 2022-06, 2022-07
06.04.2022
3.5.17.50 - 28.10.2022
3.5.17.40 - 10.06.2022
3.5.17.20
02.11.2021
3.5.17.10
23.07.2021
3.5.17.0
28.04.2021
3.5.16.50
26.05.2021
3.5.16.40
28.01.2021
3.5.16.30
19.11.2020
3.5.16.20
3.5.16.10
3.5.16.0
07.04.2020
3.5.15.50
22.06.2020
3.5.15.40
3.5.15.30
3.5.15.20
3.5.15.10
19.09.2019
3.5.15.0
3.5.14.40 - 23.08.2019
3.5.14.30
3.5.14.20 - 18.04.2019
3.5.14.10
20.02.2019
3.5.14.0 17.12.2018
3.5.13.40
16.05.2019
3.5.13.30
18.01.2019
3.5.13.20
23.10.2018
3.5.13.10
23.08.2018
3.5.13.0
(Link to Advisory 2018-06)
Compatibility Information:
10.07.2018
3.5.12.70
13.11.2018
3.5.12.60
18.09.2018
3.5.12.50
17.07.2018
3.5.12.40
24.05.2018
3.5.12.30 27.04.2018
3.5.12.20
15.03.2018
3.5.12.10
For more details see:
26.02.2018
3.5.12.0 - 20.12.2017
3.5.11.60
20.04.2018
3.5.11.50
16.02.2018
3.5.11.40 - 17.11.2017
3.5.11.30 - 17.10.2017
3.5.11.20 - 21.09.2017
3.5.11.10 - 22.08.2017
3.5.11.0 - 14.07.2017
3.5.10.60 - 23.08.2017
3.5.10.50 - 17.07.2017
3.5.10.40 - 22.05.2017
3.5.10.20 - 16.03.2017
3.5.10.10 - 14.02.2017
3.5.10.0 - 14.12.2016
3.5.9.70 - 22.02.2017
3.5.9.60 - 20.01.2017
3.5.9.50 - 17.11.2016
3.5.9.40 - 02.11.2016
3.5.8.60 - 23.09.2016
