CODESYS Control RTE SL
3.5.22.40
2302000000-SW
The product CODESYS Control RTE SL is a real-time software PLC for PC-based industrial controllers under Windows. The runtime system has its own real-time kernel and provides deterministic execution of IEC 61131-3 control applications without additional hardware components or operating system extensions.
Applications are programmed with the CODESYS Development System in all IEC 61131-3 languages (IL, ST, FBD, LD, SFC, CFC). Standard PLC features such as online change, breakpoint debugging, write/force, retain and persistent data, device logbook, user management, encrypted (TLS) communication, alarm management, recipe management as well as trace and trend recording are included. Add-ons such as the CODESYS Git integration are available via the CODESYS Store.
The Runtime Package includes drivers for the common industrial fieldbusses and protocols: EtherCAT (with Distributed Clocks), PROFINET Controller and Device, EtherNet/IP Scanner and Adapter, CANopen Manager and Device, Modbus TCP and Serial, Sercos III Master, J1939 and IO-Link Master.
For higher-level communication and IIoT scenarios, the runtime provides an OPC UA Server and Client, OPC UA PubSub, MQTT, network variables, SNMP and the CODESYS PLCHandler API for external HMI and diagnostic tools. The CODESYS IIoT libraries (REST, JSON, e-mail, MQTT, web client) and the CAA libraries provide additional function blocks for IEC 61131-3 applications.
The runtime includes target-based visualization (local display on the controller and remote display from a CODESYS panel) and browser-based web visualization. Their availability depends on the application-based license tier.
Optional functions activated through the application-based license tier include motion control with PLCopen-compliant function blocks (CODESYS SoftMotion, including CNC and robotic kinematics) and hot-standby controller redundancy.
For functions not covered by the application-based tier, dedicated CODESYS Store license modules are available, e.g. CODESYS IIoT Libraries SL for IoT function blocks, CODESYS OPC UA PubSub SL, CODESYS BACnet SL and CODESYS KNX SL for building automation, as well as approved third-party CODESYS-compatible products.
The product is licensed via an application-based license model. An overview of the available license tiers is provided on the CODESYS Store runtime licenses page.
For installation, configuration and usage details, see the CODESYS Online Help.
For ordering and version information, see the CODESYS Store product page.
Minimum CODESYS Development System V3.5 SP19 Patch 1 (recommended V3.5 SP20 or higher)
Minimum CODESYS Control RTE SL V3.5 SP19 Patch 1 or higher
Supported Windows Versions: Windows 10 / 11 / IoT Enterprise 32Bit or 64 Bit, with Multicore-CPUs
Installation of CODESYS Control RTE SL
Hyperthreading is not supported a and must be deactivated
The following CAN-PCI cards are supported:
  • Peak PCI: PCIe, MiniPCIe (SJA1000-based)
  • Ixxat: SJA1000 (PCI card)
  • Automata: all PCI cards (1 and 2 channel)
  • Innodisk: PCIe CAN adapter
  • HMS: passive CAN cards
The following Ethernet chipsets are supported:
  • Realtek
  • Intel (Pro1000 compatible)
  • Intel i210/i225/i226 (2,5G)
Following Hilscher hardware is supported:
  • PROFINET Controller: Hilscher CIFX or netX 100/500 controller with firmware 3.x
Efficency Cores (e-cores) are not supported and must be deactived
The size and functional scope of the IEC application are licensed. See the table of license tiers in the technical description.
The license is activated on a software-based license container (soft container) permanently linked to the controller, or stored on a CODESYS Key (USB dongle) for portable licensing.
Note: Without a license, the software runs in demo mode for two hours. After that, a manual restart is required.
Version .zip with packed Setup.exe (32 and 64 bit) .zip with unpacked Setup (32 and 64 bit) Release Note Release date
3.5.22.40
30.09.2026
3.5.22.30 - 23.07.2026
3.5.22.20
20.05.2026
3.5.22.10 - 02.04.2026
3.5.22.0
24.03.2026
3.5.21.60 - 22.04.2026
3.5.21.40
01.12.2025
3.5.21.30 - 25.09.2025
3.5.21.20
Includes the following Security fixes: 2025-07, 2025-08
04.08.2025
3.5.21.10 - 26.05.2025
3.5.21.0 - 18.03.2025
3.5.20.60 - 22.04.2025
3.5.20.50 - 23.01.2025
3.5.20.40 - 20.11.2024
3.5.20.30
23.09.2024
3.5.20.20 - 31.07.2024
3.5.20.10
04.06.2024
3.5.20.0 - 19.03.2024
3.5.19.70 - 02.05.2024
3.5.19.60 - 06.02.2024
3.5.19.50 - 04.12.2023
3.5.19.40 - 23.10.2023
3.5.19.30
05.10.2023
3.5.19.20
03.08.2023
3.5.19.10 - 01.06.2023
3.5.19.0
08.03.2023
3.5.18.60
31.10.2023
3.5.18.50
04.05.2023
3.5.18.40
13.12.2022
3.5.18.30
06.10.2022
3.5.18.20
03.06.2022
3.5.18.0
Includes the following Security fixes: 2021-09, 2021-11, 2022-02, 2022-03, 2022-04, 2022-06, 2022-07
06.04.2022
3.5.17.50 - 28.10.2022
3.5.17.40 - 10.06.2022
3.5.17.30 - 25.01.2022
3.5.17.20
02.11.2021
3.5.17.10
23.07.2021
3.5.17.0
28.04.2021
3.5.16.50
26.05.2021
3.5.16.40
28.01.2021
3.5.16.30
19.11.2020
3.5.16.20
3.5.16.10
3.5.16.0
07.04.2020
3.5.15.50
22.06.2020
3.5.15.40
3.5.15.30
3.5.15.20
3.5.15.10
19.09.2019
3.5.15.0
3.5.14.40
23.08.2019
3.5.14.30
3.5.14.20 - 18.04.2019
3.5.14.10
20.02.2019
3.5.14.0 17.12.2018
3.5.13.40
16.05.2019
3.5.13.30
18.01.2019
3.5.13.20
23.10.2018
3.5.13.10
23.08.2018
3.5.13.0
(Link to Advisory 2018-06)
Compatibility Information:
10.07.2018
3.5.12.70
13.11.2018
3.5.12.60
18.09.2018
3.5.12.50
17.07.2018
3.5.12.40
24.05.2018
3.5.12.30 27.04.2018
3.5.12.20
15.03.2018
3.5.12.10
For more details see:
26.02.2018
3.5.12.1 Hotfix to tackle the problems caused by the Microsoft Windows 10 update fixing the Meltdown and Spectre processor vulnerabilities. 17.01.2018
3.5.12.0 20.12.2017
3.5.11.60
20.04.2018
3.5.11.50
16.02.2018
3.5.11.42 Hotfix to tackle the problems caused by the Microsoft Windows 10 update fixing the Meltdown and Spectre processor vulnerabilities. 17.01.2018
3.5.11.40 17.11.2017
3.5.11.30 17.10.2017
3.5.11.20 21.09.2017
3.5.11.10 22.08.2017
3.5.11.0 14.07.2017
3.5.10.95 Hotfix to tackle the problems caused by the Microsoft Windows 10 update fixing the Meltdown and Spectre processor vulnerabilities. 17.01.2018
3.5.10.60 23.08.2017
3.5.10.50 17.07.2017
3.5.10.40 22.05.2017
3.5.10.20 16.03.2017
3.5.10.10 14.02.2017
3.5.10.0 14.12.2016
3.5.9.70 22.02.2017
3.5.9.60 20.01.2017
3.5.9.50 17.11.2016
3.5.9.40 02.11.2016
3.5.8.60 23.09.2016
