CODESYS Control for PLCnext SL is an adapted CODESYS Control runtime system for the Phoenix PLCnext controllers AXC F 2152 and AXC F 1152.
4.23.0.0
2302000033-SW
CODESYS Control for PLCnext SL is a CODESYS Control runtime system for the Phoenix PLCnext Controllers AXC F 2152 and AXC F 1152 (see https://www.phoenixcontact.com/). The package includes the option to use the AXIO extension modules.
To install the product on the Linux OS via the CODESYS Development System, use the the included CODESYS Deploy Tool plug-in. After each restart the runtime system will be started automatically. If no valid full license can be found, CODESYS Control runs for two hours without functional limitations before shut down.
After installing the runtime environment, the PLCnext controller can be programmed as a PLC with the CODESYS Development System.
Benefits
  • Suitable for controlling tasks in all automation fields
  • Comprehensive engineering solution with the free CODESYS Development System (V3), including extensive visualization options
  • Efficient engineering with the products of the CODESYS Professional Developer Edition (code management via link to Apache Subversion, static code analysis, runtime measurement on the PLC, comprehensive test automation, methodical application development with UML diagrams)
  • Compatible with additional add-ons and products from the CODESYS Store
  • Phoenix AXC F 2152
  • Phoenix AXC F 1152
  • PLCnext Firmware:
    • Minimum version 2023: >= 2023.0
    • Minimum version 2024: >= 2024.0.6
    • only LTS versions are supported
  • Dynamic libraries required by the CODESYS Control Runtime binary:
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
  • Ethernet ports are not physically separated (integrated switch)
22.10.2026
17.08.2026
18.06.2026
01.04.2026
12.02.2026
- 16.10.2025
26.08.2025
- 03.06.2025
- 07.04.2025
03.12.2024
- 29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
27.10.2022
  • Fixed problems with missing process data for Axioline modules
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
New independet release cycle Linux-based runtimes are now independent of the CODESYS Development System release cycle. Users profit from faster updates and bug fixes. Version number changed without compatibility break (runtime based on CODESYS Runtime Toolkit V3.5.x).
New features:
- Update to CODESYS Runtime Toolkit V3.5.16.40- Included linux packages for Edge Gateway - Add redundancy functionality (additional license required) - Support of PLCnext firmware 2021.0 - New configuration setting to change priority of device interrupts
Bug Fixes: - Fixed problems with Axioline Smart Elements - Fixed problems with retain memory - Fixed problems with thread priorities
04.03.2021
  • Support of AXC F 1152
  • Axioline driver: support of module scan
  • Axioline driver: support modules with complex parameterization (PDI read/write)
  • Various improvements and bug fixes
19.09.2019
New product
- Fully-adapted CODESYS runtime for the Phoenix PLCnext controller AXC F 2152
- Including licenses for CODESYS WebVisu, CODESYS OPC UA Server and selected CODESYS Fieldbuses
- Support of Axioline-I/O-System for analog and digital I/Os
30.07.2019
