An IEC 61131-3-compliant SoftPLC for Linux/ARM-based industrial controllers.
4.23.0.0
2302000039-SW
The CODESYS Control Linux ARM SL is an adapted CODESYS runtime system for Linux/ARM-based platforms. The performance of the runtime system is almost arbitrarily scalable via the hardware properties of the system.
To install the product on the Linux OS via the CODESYS Development System, use the the included CODESYS Deploy Tool plug-in. After each restart the runtime system will be started automatically. If no valid full license can be found, CODESYS Control runs for two hours without functional limitations before shut down.
After installing the runtime environment, the PLCnext controller can be programmed as a PLC with the CODESYS Development System.
Benefits
The runtime system supports numerous I/O interfaces, such as discrete inputs and outputs or fieldbus adapters, as well as integrated IEC 61131-3 protocol stacks. The fieldbuses are configured directly in the CODESYS Development System without using any additional tools.
  • Communication with the CODESYS Development System for programming and debugging of the IEC 61131-3 application
  • Execution of controller functions and generation of graphical user interfaces
  • Operation of I/O systems and fieldbuses
Interfaces
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
  • Connect persistent memories (Retains
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS PROFIBUS Master
Product options
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS Redundancy SL
  • CODESYS SoftMotion
  • CODESYS SoftMotion Light SL
  • CODESYS DNP3
  • OS: Debian-based Linux (32/64-bit)
  • CPU: ARMv7, ARMv8
Additional requirements
  • A SSH server must be running on the Linux system, to install the CODESYS runtime with the CODESYS Development System.
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
  • Third-party requirements: - libc >= 2.27 (2.38 on ARM32) (required by CodeMeter Runtime)
  • Other Linux distributions may also be used at your discretion but are not part of the product release and related tests.
Version ARM 32 bit ARM 64 bit Release Notes Release Date
4.23.0.0
  • Updated CodeMeter Runtime to version 9.10
22.10.2026
4.22.0.0
17.08.2026
4.21.0.0
  • Support of EWF licensing containers
  • Execution of runtime with specific user rights, not root access
18.06.2026
4.20.0.0
01.04.2026
4.19.0.0
Support of generic peripherals
12.02.2026
4.18.0.0
16.10.2025
4.17.0.0 Update on CODESYS Runtime Toolkit V3.5 SP21 P2 26.08.2025
4.16.0.0 Update on CODESYS Runtime Toolkit V3.5 SP21 P1 03.06.2025
4.15.0.0 Update on CODESYS Runtime Toolkit V3.5 SP21 07.04.2025
4.14.0.0
03.12.2024
4.13.0.0
Support of network licensing
29.08.2024
4.12.0.0
03.07.2024
4.11.0.0
23.02.2024
3.5.17.0
Initial release
20.05.2021
