CODESYS Control for emPC-A/iMX6 SL
The product extends the device software and allows end users to program a Janz Tec emPC controller with the CODESYS Development System (V3) – the free development environment for IEC 61131-3 applications.
4.23.0.0
2302000014-SW
CODESYS Control for emPC-A/iMX6 SL is a runtime environment based on CODESYS V3 for implementing a PLC with the Linux-based, real-time capable industrial controller emPC-A/iMX6 from Janz Tec AG. After installation the product, the PLC can be engineered with the CODESYS Development System (V3) from 3S-Smart Software Solutions GmbH.
  • Purchase of the applicable hardware from the company Janz Tec AG (http://www.janztec.com).
  • Download of the product CODESYS Control for emPC-A/iMX6 SL from the CODESYS Store (http://store.codesys.com).
  • Installation of the CODESYS PLC runtime environment on the hardware
Benefits
  • Suitable for controllers in all industries and sectors
  • Comprehensive engineering solution with the free CODESYS Development System (V3), including extensive visualization options
  • Efficient engineering with the products of the CODESYS Professional Developer Edition (code management via link to Apache Subversion, static code analysis, runtime measurement on the PLC, comprehensive test automation, methodical application development with UML diagrams)
  • Compatible with additional add-on and products from the CODESYS Store
Interfaces
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS J1939
Product options
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS Redundancy SL
  • CODESYS SoftMotion
  • CODESYS SoftMotion Light SL
  • CODESYS TargetVisu SL
  • SY-EPC-64001 (emPC-A/iMX6 with an RS232 port and CAN interface)
  • SY-EPC-64002 (emPC-A/iMX6 with two CAN interfaces)
  • SY-EPC-64002 (emPC-A/iMX6 with four CAN interfaces)
  • Janz Tec-Firmware: 1.6 (minimum requirement)
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
  • To use the integrated TargetVisu of CODESYS Control for emPC-AiMX6 SL the following requirements apply:
    • libQtCore.so.4
    • libQtGui.so.4
    • libQtNetwork.so.4
    • libQtWebKit.so.4
    • libQtSvg.so.4
  • To use a visualization based on CODESYS TargetVisu for Linux SL please refere to the requirements of CODESYS TargetVisu for Linux SL. Additionally a firmware based on at least debian 12 is required.
22.10.2026
17.08.2026
18.06.2026
01.04.2026
12.02.2026
- 16.10.2025
26.08.2025
- 03.06.2025
- 07.04.2025
03.12.2024
- 29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
27.10.2022
  • Update to CodeMeter V7.40
30.06.2022
01.03.2022
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
19.09.2019
New product - Multicore support for CODESYS Control for emPC-AiMX6 SL
23.08.2019
18.04.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
13.11.2018
27.04.2018
26.02.2018
 - 20.12.2017
For more details see:
20.04.2018
16.02.2018
 - 21.09.2017
 - 22.08.2017
 - 13.07.2017
 - 16.03.2017
 - 15.12.2016
