The product “CODESYS Control for BeagleBone SL” extends the Linux environment of a BeagleBone Black with the functions of a CODESYS programmable PLC.
4.23.0.0
2302000013-SW
The CODESYS runtime environment contained in the product is specially adapted to the Beaglebone Black, the community supported hardware. With a CODESYS runtime, users can realize a PLC device and use functions of the freely available development environment CODESYS Development System to configure it in IEC 61131-3.
Benefits
The software package contains an extension for the CODESYS programming environment, with which an update mechanism is integrated in order to install the runtime environment on the BeagleBone Black without LINUX knowledge. The installation of the CODESYS Runtime component on the BeagleBone Black takes place in the form of a Debian package, directly from the CODESYS Development System. The supplied examples supplement the software package with useful applications that facilitate the first steps in the application.
With the integrated CODESYS “Wink” mechanism, the hardware can be clearly assigned to an existing gateway connection by flashing the LED.
Interfaces
  • GPIOs and analog inputs, supported as local interfaces.
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS J1939
Product options
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS Redundancy SL
  • CODESYS SoftMotion
  • CODESYS SoftMotion Light SL
  • BeagleBone Black (Version C and later), BeagleBone Green, BeagleBone Blue, BeagleBone Enhanced
  • Running on official debian-based linux images from https://beagleboard.org
  • CANopen can only be used with an additional CAN-CAPE
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
  • CODESYS WebVisu: Port 9090
  • No device support for BeagleBoard-X15
22.10.2026
- 17.08.2026
18.06.2026
01.04.2026
12.02.2026
- 16.10.2025
26.08.2025
- 03.06.2025
- 07.04.2025
03.12.2024
- 29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
27.10.2022
  • Update to CodeMeter V7.40
30.06.2022
01.03.2022
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
04.03.2021
Includes support of BeagleBone Black Wireless.
04.12.2020
19.09.2019
  • Extended devcie support for BBB Wireless and BBB Enhanced
23.08.2019
18.04.2019
20.02.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
13.11.2018
27.04.2018
26.02.2018
- 20.12.2017
For more details see:
20.04.2018
16.02.2018
- 21.09.2017
- 22.08.2017
- 13.07.2017
- 21.04.2017
- 16.03.2017
- 16.12.2016
