CODESYS Control Basic S
The application-based CODESYS Control Basic S license is specially designed for the smallest applications with up to 64 I/O channels and can be used on all Control SL products without restrictions.
2302000047
From €29.00
License Control Basic S
Metric
Basic S
Basic M
Fieldbus instances
0
2
Complex fieldbus instances
0
1
thereof host instances
0
0
0
1
Number of I/O channels
64
128
Visu S
Visu S
Communication
Communication S
Communication S
DataSource Manager
Yes
Yes
Dynamic C code
No
No
No
No
CODESYS Communication
CODESYS Visualization
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
