CODESYS Connectivity Redundancy is a license that unlocks functions in other product parts. These are functionalities that enable redundant communication between the controller and other devices. Communication redundancy ensures that communication can continue via the second path if one connection fails. This feature can be used independently of the CODESYS Redundancy with only a single controller.
Redundant communication to MODBUS servers that support this feature.
CODESYS OPC UA Server
Application interface to control the redundancy properties of OPC UA Server
A detailed explanation of the function can be found in the data sheet for the respective product and in the online help.
There is a time-limited demo mode for these functionalities, i.e. the functions can be tried out without this license.
The license itself has no requirements or restrictions. Any system requirements are described in the data sheet for the respective product.
See the data sheet for the respective product.
The respective products that implement communication redundancy must be installed on the system.
