CODESYS Communication XXL
The CODESYS Communication M license enables the use of the Symbol Configuration, Communication Manager and Datasource Manager. The exchange of an unlimited number of tags is allowed.
The publishing of data is done via OPC UA. Three use cases are supported for this:
Publication of IEC variables via IEC Symbol Set Configuration. The basis is the existing application from which the symbols to be published can be selected.
The usage of OPC UA Information Models. The support is implemented in a generic way. The object- and data types defined in information models can be converted to IEC data type declarations.
Variables of an application can be published by directly selecting them without having to define a specific information model.
Receiving data is achieved by using data sources. The source can either be another CODESYS application or an OPC UA Server.
A video tutorial is available showcasing the features.
Performance classes | Number of tags |
Communication S | 512 |
Communication M | 4096 |
Communication XXL | unlimited |
This license also acts as an upgrade license to upgrade from an already purchased application-based license (Base License) to a higher-performance license. The costs of the already purchased license (Base License) will be fully credited.
The CODESYS Communication S license is already included in the runtime system license by default.
Programming System | CODESYS Development System V3.5.19.10 or higher CODESYS Communication V4.3.0.0 or higher |
Runtime System | CODESYS Control V3.5.19.10 or higher |
Supported Platforms/Devices | CODESYS Store runtime products for Windows and Linux |
Additional Requirements | See license agreement. After installation, the user is responsible for implementing and checking the functionality of the combination of the software package and hardware according to device specifications. |
Restrictions | - |
Licensing | Single device license: The license can be used on the target device/PLC on which the CODESYS runtime system is installed. Licenses are activated on a software-based license container (soft container), which is permanently connected to the controller. Alternatively, the license can be stored on a CODESYS Key (USB dongle). By replugging the CODESYS Key, the license can be used on any other controller. Note: In demo mode (no license for runtime and OPC UA), the software runs for two hours without a license. After that, a manual restart is required. |
Required Accessories | Optional: CODESYS Key |
