CODESYS Communication M
The CODESYS Communication M license enables the use of the Symbol Configuration, Communication Manager and Datasource Manager. The exchange of up to 4096 tags is allowed.
2302000057
€59.00
The publishing of data is done via OPC UA. Three use cases are supported for this:
  • Publication of IEC variables via IEC Symbol Set Configuration. The basis is the existing application from which the symbols to be published can be selected.
  • The usage of OPC UA Information Models. The support is implemented in a generic way. The object- and data types defined in information models can be converted to IEC data type declarations.
  • Variables of an application can be published by directly selecting them without having to define a specific information model.
Receiving data is achieved by using data sources. The source can either be another CODESYS application or an OPC UA Server.
A video tutorial is available showcasing the features.
Performance classes Communication
Performance classes
Number of tags
Communication S
512
Communication M
4096
Communication XXL
unlimited
Base License
This license also acts as an upgrade license to upgrade from an already purchased application-based license (Base License) to a higher-performance license. The costs of the already purchased license (Base License) will be fully credited.
The CODESYS Communication S license is already included in the runtime system license by default.
CODESYS Development System V3.5.19.10 or higher CODESYS Communication V4.3.0.0 or higher
CODESYS Control V3.5.19.10 or higher
Supported Platforms/Devices
Note: In demo mode (no license for runtime and OPC UA), the software runs for two hours without a license. After that, a manual restart is required.
