The CODESYS CANopen Manager SL is not compatible with application-based licenses.
Configurator, protocol stack and diagnostics for CANopen Manager, fully integrated in the IEC 61131-3 development system.
2303000233
€100.00
The CANopen support in CODESYS is based on the standard implementation of the CAN-Interface (CAN Minidriver interface). If your target device programmable with CODESYS is equipped accordingly you can immediately use CODESYS CANopen.
CODESYS CANopen Manager offers
  • A CANopen Manager configurator based on EDS and DCF files fully integrated in the Development System CODESYS
    ⇒ No additional tools required for the configuration of the bus system or the I/O data.
  • A CANopen communication stack in form of a CODESYS CiA 301 library
    ⇒ The protocol stack is portable across different platforms and does not have to be fully implemented on the device.
    ⇒ The IEC 61131-3 Development System compiles the stack and the application code into native machine code and loads it onto the controller.
  • A CiA 405 application interface for the diagnosis and use of SDOs
    ⇒ Extensive functionality without needing any additional software tools
CODESYS Control V3
Target device needs CAN Minidriver implementation.
