CODESYS BACnet SL
CODESYS BACnet SL is a product that extends the functionality of a device in order to be able to implement applications in building management systems compliant to ANSI/ASHRAE Standard 135-2020. This function is integrated directly into the CODESYS Development System.
2.0.0.0
2303000005
€300.00
BACnet
BACnet ( B uilding A utomation and C ontrol Net work) is a network protocol for building automation. It is developed by the American Society of Heating, Refrigeration, and Air-Conditioning Engineers (ASHRAE), standardized by ASHRAE 135-2020, ANSI, and ISO 16484-5 and continuously updated. This open standard enables building operators to use BACnet compliant devices from different manufacturers interoperably.
BACnet basics
BACnet defines an object model in which a physical device is represented by a group of standardized BACnet objects. Each object type provides a well defined list of properties. BACnet devices provide various services and procedures to other devices, depending on the complexity of the device. So-called BIBBs (BACnet Interoperability Building Blocks) define the set of services and procedures which must be supported on the server and client side in order to realize certain requirements of the system. BACnet devices are classified by a device profile. Device profiles can range from a simple smart sensor (B-SS) to a complex building controller (B-BC). The PICS (Protocol Implementation Conformance Statement) document associated with a BACnet device lists all supported BIBBs, object types, character sets, and communication options. BACnet devices communicate over network, in most cases via BACnet/IP and to a lesser extent via BACnet MS/TP (BACnet Manager-Subordinate Token-Passing).
CODESYS BACnet
CODESYS BACnet SL enables the implementation of building automation applications in compliance with ANSI/ASHRAE Standard 135-2020. All object types defined in ANSI/ASHRAE Standard 135-2020 and all services required for application development are supported. Integrated libraries, devices and plug-ins enable the configuration and implementation of an application with BACnet support. For example, to provide an analog value (BACnet Analog Value) in the BACnet network, a corresponding BACnet Analog Value device simply has to be inserted in the device tree of the CODESYS application.
Picture 1: Example of a simple BACnet application in CODESYS
  • CODESYS Control V3.5.19.0 or higher (für protocol revision 25)
  • CODESYS Control V3.5.15.0 or higher (für protocol revision 15)
  • CODESYS Control for Win (not RTE)
  • CODESYS Control for Linux
  • CODESYS Control for Raspberry Pi
  • CODESYS Control for BeagleBone
  • CODESYS Control for emPC-A/iMX6
  • CODESYS Control for PLCnext
  • CODESYS Control for WAGO Touch Panels 600
Note: Other platforms are supported provided that the device manufacturer also supports CODESYS BACnet.
- 07.12.2023
- 23.08.2022
26.08.2021
13.01.2021
14.08.2020
29.05.2020
CODESYS BACnet 1.5.0.0 contains enhancements which are mainly focused upon flexibility and efficiency improvements for BACnet application development. Most prominently: - BACnet object properties can be configured regarding existence, writability and persistence - a default implementation for BACnet Trend Log - examples included in CODESYS BACnet package - source code of BACnet default implementations included in CODESYS BACnet package In general lots of improvements have been added to make it easy to build your specific BACnet B-BC and make it pass the according BACnet conformance tests.
04.02.2020
major improvements:
  • added BACnet object types Integer Value, Large Analog Value, Positive Integer Value
  • BACnet “configuration devices” to add in device tree underneat ETH (for BACnet IP)
  • extended BACnet server objects with configuration information regarding existence, writability and persistence of properties
  • default implementation for BACnet object persistence
  • default implementation for BACnet backup/restore
  • default implementation for BACnet TimeSync and UTCTimeSync
  • default implementation to limit BACnet client creatable object types
03.09.2019
Object types Global Group, Group, Life Safety Point and Life Safety Zone has been added. The libary BACnetDefaultImpl has been added.
27.03.2019
CODESYS BACnet 1.2.1.0 implements BACnet protocol revision 14
26.07.2018
CODESYS BACnet  1.2.0.0 ensures 64 bit compatibility. 02.11.2017
19.01.2017
