CODESYS 4
CODESYS 4 is a web-based IEC 61131-3 development environment for industrial control and automation technology, available for Windows x64, Linux x64, and Linux ARM64.
2101000024
CODESYS 4 is the new, web-based development environment for programming programmable logic controllers in accordance with IEC 61131-3. Users work directly in a modern browser and are not tied to any particular operating system. Existing libraries from the CODESYS Development System remain compatible and can continue to be used in parallel throughout the lifecycle – protecting existing know-how and investments.
With its open project storage, CODESYS 4 integrates seamlessly into modern software development workflows: version control systems, diff tools, and CI/CD pipelines can be used directly, and dependencies are managed reliably and transparently. An Extension Platform allows the environment to be extended modularly with additional functionality.
CODESYS 4 adapts flexibly to the way you work – from local single-user use and collaborative team development on a multi-user server through to full automation in scripts and CI/CD pipelines. This makes engineering more efficient, more collaborative, and future-proof throughout the entire product lifecycle.
For more information, visit www.codesys.com.
Programming system
Runtime system
CODESYS Runtime V3.5 SP19 and newer
Supported platforms
  • Windows x64
  • Debian Linux x64
  • Debian Linux ARM64
Hardware requirements
  • RAM (available): 3 GB minimum, 8 GB recommended
  • Disk space (available): 4 GB minimum
  • Linux values refer to single-user operation
Supported browsers
Tested with current versions of Chromium based browsers (Chrome, Edge) and Mozilla Firefox
Additional requirements
  • Windows: .NET Desktop Runtime 8.0 and ASP.NET Core Runtime 8.0
  • Linux amd64: aspnetcore-runtime-8.0 (>= 8.0.30) via apt
  • Linux arm64: ASP.NET Core Runtime 8.0 (>= 8.0.30) via install script (no Debian package available)
Supported device descriptions
  • CODESYS Control for Raspberry Pi 64 SL
  • CODESYS Control RTE V3
  • CODESYS Control Win V3
  • CODESYS Control for Linux ARM64 SL
  • Application projects need an explicit conversion step between CODESYS Development System 3 and CODESYS 4
  • Certificate authentication and TLS encryption for PLC communication are not supported yet
  • Multi-user server operation (Linux) requires an external reverse proxy; recommended only in secure networks
  • Windows installer: local desktop use only, no server
  • Touch screen support is limited; small screens are not supported
Required accessories
Version Windows (.msi) Linux AMD64 (.deb) Linux ARM64 (.deb) Release Notes Release Date
1.0.0.0 - 24.09.2026
