CANopen Example
This sample project deals with the programming interface of the CANopen master and CANopen slave communication stack. The project contains examples for SDO, NMT, diagnostics, and the dynamic configuration of communication parameters (baud rate, network ID, node ID), and many more.
000065
This sample project contains different examples for using the programming interface of the CANopen master and CANopen slave stack. Topics that are handled include the following:
  • SDO (expedited, segmented, block), object directory access
  • Network Management (NMT)
  • Diagnostics (CANopen state, EMCY)
  • Event handler for object directory and CANopen manager state machine
  • Reconfigure: Dynamic changing of baud rate, network ID, and node ID
  • Access to CAN configuration by means of the device diagnosis library
