Cam Editor
This example project shows how to use the cam editor. The online cam editor is a visualization template which displays a cam table in the visualization. The element allows modifying the cam in online mode.
000049
The visualization element is provided as a visualization template (SMC_VISU_CamEditor) of the library SM3_Basic. It is added to the visualization by use of the visualization element “Frame” and the command “Frame Selection” from the context menu.
