The AS Data Manager is a powerful library for flexible runtime data and recipe management in modern automation projects. It replaces static configurations with a dynamic, structured and fully integrated approach, ensuring that your data always reflects the current state of your application.
2.2
2112000023
€150.00
Youtube Video Link : https://www.youtube.com/watch?v=N2HZ_mMIRBk&t=0s
application.
The AS Data Manager eliminates the need for centrally maintained recipe definitions. Instead,
recipes are automatically derived from the actual data structures used in your application. This
approach ensures consistency, maintainability and scalability, even as your project evolves: new
parameters are instantly available without manual synchronization, significantly reducing
engineering effort.
Key Features
Hierarchical data organization
Support for all data types
Flexible visualization
Multilingual support
Automatic unit conversion
Runtime visibility control
Open storage interface
Forward compatibility – existing recipes remain valid even when new parameters are added
Benefits at a Glance
Eliminates static definitions
Reduces engineering and maintenance effort
Avoids inconsistencies between code and recipes
Scales seamlessly with growing applications
Typical Applications
Machine parameter management
Recipe handling in industrial automation
Runtime configuration of machines and processes
Data-driven optimization and monitoring
The AS Data Manager transforms recipe management into a dynamic, structure-driven process,
reducing complexity and ensuring long-term compatibility of your data.
Requirement
Value
CODESYS Development System V3.5.22.30
Target System
CODESYS Control V3.5.22.30
No restriction
Single Device Only
Required Accessory
