Application Manager
This example shows how the “CmpApp” library can be used to retrieve information about projects and applications as well as area addresses and sizes of data types. It is also possible to control an application from within another application.
1.0.0.1
000002
The use of the system library “CmpApp” is demonstrated. The library can retrieve information about projects and applications as well as area addresses and sizes of data types. Retain variables can be stored in files and it is possible to start, stop and reset an application from within another one.
