Application Composer Examples
This software package consists of a variety of sample applications. Each one details a specific functionality of CODESYS Application Composer. The result is an overview of the application capabilities as well as derived reference points for the implementation of the each domain.
1.0.0.2
000074
This software package contains sample projects that are tailored for the different subdomains of CODESYS Application Composer.
  • Example: Decoupled modules
    This example demonstrates how to use decoupled modules. Decoupled modules can be used as both top-level modules and lower-level modules in slots.
  • Example: StaticDeviceGenerator
    This example demonstrates how to use automated generation of devices with CODESYS Application Composer and static device assignment.
  • Example: FlexibleDeviceGenerator
    This example demonstrates how to use automated generation of devices with CODESYS Application Composer and flexible device assignment.
  • Example: ExtensionModules
    This example demonstrates how to use extension modules. Extension modules are used if existing modules do not correspond to the defined requirements.
  • Example: MacroModules
    This example demonstrates how to use macro modules. With a valid license for CODESYS Application Composer, this example creates newmacro-modules from the module tree.
  • Example: MappingEditor
    This example demonstrates how the mapping editor is used for the I/O mapping of modules with the hardware available in the CODESYS Application Composer project.
  • Example: Proxy (instances)
    This example demonstrates how to use proxies. Proxies make is possible for module instances to communicate with each other. These are parts of applications on different controllers.
  • Example: SequenceEditor
    This example demonstrates how to use the sequence editor that is integrated in CODESYS Application Composer. With the associated graphical editor, modules are displayed and edited sequentially.
  • Example: Visualization (visualization generator)
    This example demonstrates how to use the visualization generator. The generator is used if a visualization should be generated directly from the module tree when using CODESYS Application Composer.
CODESYS Development System V3.5.7.0 or higher
CODESYS Control V3.5.7.0
Not relevant
See the additional requirements of each example
See the restrictions of each example
See the licensing of each example
See the required accessories of each example
Version Release Notes
Release Date
- 06.06.2018
