CODESYS Control for Raspberry Pi SL
CODESYS Control for Raspberry Pi SL is an adapted CODESYS Control runtime system for the Raspberry Pi (PLC extension), for non-commercial use.
Version:
4.0.0.0
Order number:
2302000009
€50.00 plus VAT
  • Buy 4 for €47.50 each and save 5%
  • Buy 10 for €45.50 each and save 9%
  • Buy 25 for €42.50 each and save 15%
  • Buy 50 for €40.50 each and save 19%
€50.00 plus VAT
CODESYS Control for Raspberry Pi SL contains a CODESYS Control application for all Raspberry Pi, including the Compute Module (see http://www.raspberrypi.org/) as well as the capability to use the extension modules and several devices/breakouts with SPI, I²C or 1-wire communication interface.
This product can be installed with the included CODESYS Deploy Tool plug-in via the CODESYS Development System on a Linux distribution Raspbian. After each restart the runtime system will be started automatically. If no valid full license can be found, CODESYS Control runs for two hours without functional limitations before shut down.
Detailed information can be found in the Online Help.
Interfaces
The CODESYS device description does support the following components:
  • CODESYS OPC UA Server, as full version for data exchange
  • CANopen via EL6751 Gateway
  • Raspberry Pi Camera
  • I²C interface, with SenseHat, SRF02, Adafruit PWM, MPU6050 Gyro, MPU9150 Gyro, AK8975 Compass
  • SPI interface, with MCP3008, MCP23S17, PiFace Digital, PiFace Control Display
  • One-wire interface, with DS20B18
  • GPIO
Visualization
  • CODESYS WebVisu, is included as full version in the delivery of the runtime package.
Fieldbus support
With the delivery of the Runtime Package the following fieldbuses are supported:
  • CODESYS CANopen Manager / Device
  • CODESYS EtherCAT Master
  • CODESYS EtherNet/IP Scanner / Adapter
  • CODESYS J1939
  • CODESYS Modbus TCP Master / Slave
  • CODESYS Modbus Serial Master / Slave
  • CODESYS PROFINET Controller / Device
Product options
Further products can be licensed for a fee:
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS SoftMotion SL
  • CODESYS SoftMotion CNC+Robotics SL
Collapse
Programming System
CODESYS Development System V3.5.16.20 or higher
Runtime System
CODESYS Control V4.0.0.0 based on CODESYS Runtime Toolkit V3.5.16.20
Supported Platforms/ Devices
All Pi models
Note: Use the tool “Device Reader” to find out the supported features of your device (free of charge component of CODESYS Development System).
Additional Requirements
  • The CODESYS Control requires a network interface (LAN, WLAN), especially with the Raspberry Pi Compute Module and the Raspberry Pi ZERO.
  • If the product is used for industrial purposes, it is the responsibility of the system manufacturer to ensure compliance with the necessary specifications.
  • The operating system “Raspbian” (from version 9 “Stretch) https://www.raspberrypi.org/downloads/
  • Dynamic libraries needed by the CODESYS Control Runtime binary:
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
Restrictions
  • The combination of Raspberry Pi and a CODESYS Runtime is for test and teaching purposes.
  • No commercial use. For this, the CODESYS Control for Raspberry Pi MC SL must be used.
  • The runtime system does not have real-time behavior. Its Jitter depends on many factors, especially on parallel executed Linux applications, and is ideally approximately 50 µs with maximum values of approximately 400 µs.
Licensing
License activation optional on CODESYS Key or CODESYS Softcontainer (free of charge component of CODESYS Controls). Licensing via CODESYS Softcontainer is strictly linked to the selected hardware.
Note: Without a license the software runs in demo mode for two hours (manual restart is needed).
Required Accessories
  • SD-card (minimum 4GB)
  • Optional: CODESYS Key
Version history
Version Release Notes Release date
4.0.0.0
New independet release cycle
Linux-based runtimes are now independent of the CODESYS Development System release cycle. Users profit from faster updates and bug fixes.
Version number changed without compatibility break (runtime based on CODESYS Runtime Toolkit V3.5 SP16 Patch2).
Includes minor improvements and bug fixes.
04.12.2020
3.5.16.20
Quality update with minor improvements and bug fixes. Includes fix for latest Raspberry Pi OS version.
24.09.2020
3.5.16.10
Includes the following Security fixes: 2020-05
22.07.2020
3.5.16.0
Main update with improvements and bug fixes.
Includes the following Security fixes: 2019-08, 2019-10, 2020-01, 2020-02, 2020-03, 2020-04
05.05.2020
3.5.15.40
Includes the following Security fixes: 2020-02, 2020-03
25.03.2020
3.5.15.30
Includes the following Security fixes: 2020-01
23.01.2020
3.5.15.20
Includes the following Security fixes: 2019-10
19.11.2019
3.5.15.10
  • Quality update with minor improvements and bug fixes
  • Support of Pi4
19.09.2019
3.5.15.0
  • Support the new model Raspberry Pi 3 Model A+
  • Removal of SoftMotion license - available as separate product
  • General runtime improvements and bug fixes
Includes the following Security fixes: 2019-01, 2019-02, 2019-03, 2019-04, 2019-06, 2019-07
29.07.2019
3.5.14.40
23.08.2019
3.5.14.30
24.06.2019
3.5.14.20
Includes the following Security fixes: 2019-02, 2019-03
18.04.2019
3.5.14.10
Security update:
20.02.2019
3.5.14.0
17.12.2018
3.5.13.30
Security update:
18.01.2019
3.5.13.20
Security update:
23.10.2018
3.5.13.0
Security update:
  • Fix in CmpOPCUAServer, which crashes when invalid request is sent
  • Fix in CmpFileTransfer, with possible access of unauthorized file access to all system files
  • Fix in CmpWebServer, with possible run out of file descriptors
  • Fix in CmpOpenSSL, with an update to OpenSSL 1.0.2o
10.07.2018
3.5.12.70
Security update:
13.11.2018
3.5.12.30 27.04.2018
3.5.12.10
26.02.2018
3.5.12.0  - 20.12.2017
3.5.11.60
Beside other fixes this is a security update which solves the issues noted in Advisories 2018-04 and 2018-05.
For more details see:
20.04.2018
3.5.11.50
Beside other fixes this is a security update which solves the issue noted in Advisory 2017-09.
16.02.2018
3.5.11.20  - 21.09.2017
3.5.11.10  - 22.08.2017
3.5.11.0  - 13.07.2017
3.5.10.20  - 16.03.2017
3.5.10.0  - 15.12.2016
Review 236 to 240 of 250 total
Sehr schön Review by Rotheman
Functionality
Quality
Der Pi lässt sich mit dem Beispiel gut einbinden (Posted on 11/01/2016)
Gut Review by andreas.thuem@tele2.de
Functionality
Quality
Gut (Posted on 02/01/2016)
Programmierung Ausbildung Review by HagnF
Functionality
Quality
Für den schulischen Einsatz hervoragend geeignet. Die Echtzeitfähigkeit ist heir kein Thema. Mehr als eine Alternative, um den Schüler an die iEC Programmierung hernazuführen und damit vertraut zu machen. Die Anbindung industrieller Bussytem spannt den Bogen zur Welt der Automatisierung. Toll
Ich würde mir wünsche, dass noch eine Target Visu folgt, sofern dies technisch realistisch darstellbar ist. (Posted on 28/12/2015)
CoDeSys für Unterricht Review by Nagel
Functionality
Quality
Camera Einbindung funktioniert "CameraStream.project" nicht. Es kann nicht auf "webvisu.htm" zugegriffen werden. Fehlermeldung Server antwortet nicht. (Posted on 21/12/2015)
Great!!! Review by Fabrizio Paccagnella
Functionality
Quality
Usefull to develope some training project with raspberry teaching platform. I'm learnig a lot! (Posted on 17/12/2015)
You may also be interested in the following product(s)
CODESYS Support Ticket
€100.00 plus VAT
Add to My Wishlist
CODESYS Control Linux MC SL
€100.00 As low as: €81.00 plus VAT
Add to My Wishlist
Add to My Wishlist
Screenshots
Write Your Own Review
Only registered users can write reviews. Please, log in or register
