POWERLINK Configuration Editor
This product allows the configuration of POWERLINK networks.
000086
Industrial Control Systems implementing CODESYS can easily be turned into a POWERLINK Master (Managing Node – MN). The integration of the free open source openPOWERLINK stack and the additional CODESYS Runtime components from BE.services allow full support of the POWERLINK technology.
The configuration of the POWERLINK network is available, fully integrated in CODESYS, with this package.
This package provides all necessary additional software components for unlimited use on Raspberry Pi and BeagleBone Black target platforms.
BE.services GmbH
An der Stadtmauer 4
87435 Kempten / Germany
Tel: +49-831-960-699-91
support@be-educated.net
BE.services GmbH
An der Stadtmauer 4
