OSCAT BUILDING
This library is a port of the OSCAT BUILDING library to CODESYS Version 3. The library contains function blocks for building controls.
604302
OSCAT stands for “Open Source Community for Automation Technology”.
OSCAT creates an open source library referenced to the IEC 61131-3 standard which can be dispensed with vendor-specific functions and therefore ported to all IEC 61131-3 compatible programmable logic controllers. This library is a port of the OSCAT BUILDING library to CODESYS Version 3. The library contains function blocks for building controls.
The library OSCAT BASIC contains functions to following subjects:
  • Actuators
  • Heating, air conditioning and climate
  • Electro technology
  • Jalousie control
Programming system
CODESYS Development System Version 3.5.5.0 or higher
Runtime system
CODESYS Control Version 3.5.5.0
All 32 bit platforms
Additional requirements
64 bit controller are not supported
Support is given by the users in the forum (see www.oscat.de). A claim for support does not exists, even if the library or parts of the library are faulty. The support in the forum under the OSCAT is provided for users voluntarily and with each other.
