The HVAC KNX Library enables direct retrieval of KNX IP data from applications through KNX IP interfaces via UDP. A master function block is placed and individual group address function blocks are linked to this master.
Description and documentation: HVAC KNX Library
This solution complements ideally with the HVAC Building Automation Package.
| Development System | CODESYS Development System V3.5.17.2 or higher |
| Runtime System | CODESYS Control V4.2.0.0 or higher |
| Supported Platforms | All CODESYS runtime systems in the version specified above |
| Licensing |
Single device license: The license can be used on the controller where the CODESYS runtime system is installed. License activation is done on a software-based license container (soft container) that is permanently bound to the controller. Alternatively, the license can be stored on a CODESYS Key (USB dongle). By plugging the CODESYS Key into a different controller, the license can be used on that controller. Without license acquisition (download only), the library functions for 30 minutes without functional limitations (Demo). License: HVAC KNX Library License SL Note: Use the "Device Reader" project to determine the functions supported by the controller. "Device Reader" is available free of charge in the CODESYS Store. |
