The HVAC ModbusIO2 Library integrates powerIO® H1.X I/O modules directly into your CODESYS V3 application. The library enables quick commissioning without complex engineering – a master function block communicates with the respective slave blocks of the I/O modules.
Description and documentation: HVAC ModbusIO2 Library
This enables you to, for example:
All modules in shop: powerIO® Modbus I/O Modules
| Development System | CODESYS Development System V3.5.17.2 or higher |
| Runtime System | CODESYS Control V4.2.0.0 or higher |
| Supported Platforms | All CODESYS runtime systems in the version specified above |
| Supported Hardware | powerIO® H1.X I/O modules (H1.8AI, H1.8AO, H1.16DI, H1.8DO, H1.8DO-R, H1.4DO-R, H1.4DIO-R, H1.4DI2DO-R-3P) |
| Licensing |
License-free: This product is free to use without license acquisition. The library is provided free of charge for use with powerIO® H1.X I/O modules. Note: Use the "Device Reader" project to determine the functions supported by the controller. "Device Reader" is available free of charge in the CODESYS Store. |
