Horter & Kalb - I2C-Support für Raspberry PI
Software Package for CODESYS Development System to integrate the assemblies of the Horter & Kalb PLC training rack.
000068
The library contains two sample programs to read out the digital and analog input modules as well to control the digital and analog output modules via the I2C bus from the Raspberry Pi. See http://www.horter.de/ for more information.
Programming system
CODESYS Development System Version 3.5.6.20 or higher
Runtime system
CODESYS Control for Raspberry Pi SL Version 3.5.6.20 or higher
Additional requirements
Required Accessory
Horter & Kalb
Horter & Kalb
Inhaber Jürgen Horter
Klinikumallee 23
95445 Bayreuth
+49 (0)921 68374
mail@horter.de
Horter & Kalb
Horter & Kalb
Klinikumallee 23
95445 Bayreuth
