Company Holidays: December 22, 2025 – January 5, 2026
English/Russian Keyboard Dialog
English/Russian keyboard dialog
1.3.0.0
000079
This package provides the ability to implement switchable keyboard dialogs in the project. The keyboard includes English and Russian layouts with uppercase and lowercase letters. The keyboard works with WSTRING values of the input/output variable and title.
CODESYS Development System V3.5.6.0
Target System
CODESYS Control V3.5.4.0
Required Accessory
Company PC Prolog
Company PC Prolog
October Revolution Str. 9
214000 Smolensk
Russia
+7-481-2-38-29-31
info@prolog-plc.ru
Company PC Prolog
Company PC Prolog
214000 Smolensk
Russia
