CODESYS Priority Support
In case of technical problems when using products from the CODESYS Store, the CODESYS OEM Support will be happy to help you with the purchase of a CODESYS Priority Support.
Procedure for processing your CODESYS Priority Support
Redeeming and managing CODESYS Priority Support
If you have purchased a Support Ticket, there are two important places where you can find information about it:
To redeem your ticket, click on the menu item " My Support Authorizations " in your Store account. Here you can describe your request. Please attach all information that may be helpful for processing your request so that our support team can answer your question as quickly as possible. For more details, please refer to the following list.
If you would like to attach project files or other information, please use the CODESYS Helpdesk.
What information is required to process a support case?
In which cases do you not need a CODESYS Priority Support?
