CODESYS Depictor
The CODESYS Depictor allows creating and displaying 3D models and linking their geometrical relations (i.e. axis angles) to CODESYS applications. It is possible to display and animate machine parts (e.g. robots) or entire production lines in CODESYS.
(A demo license is available for testing.)
1.2.0.0
2101000008
€1,100.00
Workstation License
The CODESYS Depictor is used for the flexible creation, illustration and animation of 3D models. For the creation of the 3D models, poses (geometrical relations / transformations) and elements (3D geometries) can be placed in a tree structure indicating the relation to each other. The pose properties (e.g. rotation angle) can be linked to CODESYS application variables, so that the whole 3D model can be animated.
CODESYS Development System V3.5.16.30 or higher
CODESYS Control V3.5.16.30 or higher
The CODESYS Depictor uses the free 3D engine “Irrlicht” (http://irrlicht.sourceforge.net/license/ ).
- 22.05.2025
- 16.06.2021
Improvements: - Object models are positioned offline using the initialization data - Depictor Model remains when debugging the visualization. Bugfix: - Depictor: No documentation is available in the library manager after installation of the depictor
12.03.2020
12.02.2019
