CODESYS Control for Linux SL
CODESYS Control Linux SL is an IEC 61131-3-compliant SoftPLC for PC-based industrial controllers running on Linux with soft real-time properties.
4.23.0.0
2302000005-SW
CODESYS Control Linux SL converts an industrial PC into a high-performance PLC – scalable to nearly any degree by the PC performance and choice of application-based license. The system is suitable for applications without hard demands on the real-time behavior.
Benefits
The runtime system supports numerous I/O interfaces, such as discrete inputs and outputs or fieldbus adapters, as well as integrated IEC 61131-3 protocol stacks. The fieldbuses are configured directly in the CODESYS Development System without using any additional tools.
  • Communication with the CODESYS Development System, also for debugging the running application
  • Execution of controller functions and generation of graphical user interfaces
  • Operation of I/O systems and fieldbuses
Interfaces
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
  • Connect persistent memories (Retains
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS PROFIBUS Master
Product options
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS Redundancy SL
  • CODESYS SoftMotion
  • CODESYS SoftMotion Light SL
  • CODESYS DNP3
Runs on Debian-, RedHat-based Linux (64-bit)
Supported Hilscher hardware:
  • PROFIBUS Master: Hilscher CIFX or netX 100/500 controller with firmware 2.8.0.0
  • PROFINET Controller: Hilscher CIFX or netX 100/500 controller with firmware 3.x
Additional requirements
  • A SSH server must be running on the Linux system, to install the CODESYS runtime with the CODESYS Development System.
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
  • Third-party requirements: - libc >= 2.27 (required by CodeMeter Runtime)
IEC applications are bound to one CPU core.
Other distributions may also be used at your discretion but are not part of the product release and related tests.
  • Updated CodeMeter Runtime to version 9.10
22.10.2026
17.08.2026
  • Support of EWF licensing containers
  • XDP support of Ethercat and Profinet
  • Execution of runtime with specific user rights, not root access
18.06.2026
01.04.2026
Support of generic peripherals
12.02.2026
16.10.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 P2
26.08.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 P1 03.06.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 07.04.2025
03.12.2024
Support of network licensing
29.08.2024
03.07.2024
23.02.2024
Major Features of new version
  • Update to CodeMeter V7.60c
  • Support of DNP3 protocol
Includes the following Security fixes: 2023-05 <https://customers.codesys.com/index.php?eID=dumpFile&t=f&f=17765&token=04e117e1408fdb8e02b4bc821aa3be819668aef4&download=>, 2023-10 <https://customers.codesys.com/index.php?eID=dumpFile&t=f&f=17809&token=c3b4e3ec4956099de26f0c6caf194d1ba341040a&download=>
31.10.2023
- 27.07.2023
05.04.2023
02.02.2023
27.10.2022
30.06.2022
  • Update to CodeMeter V7.40
18.03.2022
4.4.0.0 Recalled at March 22, 2022. We strongly advise you to replace all versions 4.4.0.0 in the field with this corrected version 4.4.1.0. 01.03.2022
  • Update to CodeMeter Runtime V7.21a
01.09.2021
Important Note
Compatiblity information
Known limitations
Includes the following Security fixes: 2020-05, 2020-06, 2021-01, 2021-04
16.06.2021
04.03.2021
Includes support of CODESYS PROFIBUS for CIFX.
04.12.2020
19.09.2019
  • Support of software-based licensing
Includes the following Security fixes: 2019-01, 2019-02, 2019-03, 2019-06, 2019-07
23.08.2019
18.04.2019
20.02.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
