Pigeon for CODESYS Control
CODESYS Control for Pigeon allows users to program the Pigeon computers by using the CODESYS Development System.
2.0.0.0
000099
CODESYS Control for Pigeon contains support for the Pigeon computers family (RB100, RB300, RB100-CM3, RB300-CM3). Pigeon is a series of computers for use in control and automation systems. Pigeon computers have a rich set of inputs and outputs and a wide choice of interfaces (RS-232, RS-485, CAN, USB, 1-wire, HDMI). Interfaces, inputs and outputs are robust and meet requirements of EN 61326-1:2013 norm for industrial electromagnetic environments.
After installation of the CODESYS Control runtime system for Raspberry Pi and CODESYS Control for Pigeon, the Pigeon acts as a CODESYS controller, which can be engineered with the CODESYS Development System (V3). Device drivers for the following I/O are included:
  • Optoisolated Digital Inputs
  • Dry Contact Inputs
  • Digital Outputs
  • Analog Inputs
  • Analog Outputs
CODESYS Development System version 3.5.11.0 or higher
Target System
CODESYS Control version 3.5.11.0 or higher
Supported Platforms / Devices
Pigeon RB100, Pigeon RB100-CM3, Pigeon RB300, Pigeon RB300-CM3, Pigeon RB700
CODESYS Control for Raspberry Pi SL version 3.5.11.0 or higher
Required Accessory
KRISTECH Krzysztof Kajstura
Porzeczkowa 12
43-450 Ustron
Poland
support@kristech.eu
Porzeczkowa 12
43-450 Ustron
Poland
  • Pigeon RB700 support added
  • Support of CODESYS 3.5.16.70.
2022-04-26
First release in Store.
2017-08-16
