CODESYS Academy Training V3 Application Composer - Online
Organizer / Trainer: Patrick Rohloff
Event Location: Online
Event Date: 02.06.2026 - 03.06.2026
Daily (from - to): 08:30 - 16:30 (CEST)
Language: EN
The aim of the event is to familiarize participants with the CODESYS Application Composer. The target group consists of device manufacturers and application developers in the fields of factory, process, and building automation as well as energy automation. Using application examples, the event will demonstrate how the tool can be used. In addition, you will gain a solid insight into creating your own technology modules.
Online
With the CODESYS Application Composer, complete control applications can be assembled and parameterized from previously created software modules. Modules are functional program units that can correspond to machine or plant components as well as software functions. In addition to program code, they typically contain components such as visualization elements, parameterization, or I/O assignments. They therefore cover almost all programming aspects offered by CODESYS. The configuration of the modules is carried out in the module tree.
Contents
Important features of the CODESYS Application Composer:
Concept
Module tree
Technology module
Slot / Multi-slot
Parameters
I/Os
Page and embedded visualization
Device generator
The event is suitable for device manufacturers and machine builders who want to automate the creation of CODESYS projects using the CODESYS Application Composer.
For example, the following aspects can be covered:
Series machines that are equipped and configured according to customer specifications.
Special-purpose machines or plants built from recurring units.
Systems consisting of many base modules of the same type, e.g., in building or process automation.
Benefits for application engineers: Efficient and intelligent software design and reuse of code for similar applications or applications with many base modules of the same type (without copy and paste).
Required accessories:
PC or laptop
Webcam, microphone
Additional monitor recommended
Microsoft Teams
Scope of delivery:
Online training
Training documentation
Certificate upon successful completion of the training
Notes on participation:
Recording of the training is not permitted.
Please note that we only allow participation for attendees who transmit their camera image.
| Is free | No |
| Manufacturer | INT-EN-training |
| Disable Add To Cart | No |
