STweep Formatter for CODESYS (Demo)
STweep is a must-have tool for developers and companies who want to speed up development.
STweep for CODESYS is a source code formatter for Structured Text.
It helps you enforce a consisting code style based on your preferences.
This is a 30 day unrestricted demo.
4.3.1.0
2101000014
Plus 19% VAT
Main functionalities:
  • Configurable code style
  • Line breaking of long lines
  • Aligning of similar code in columns (e.g. variable declarations and assignments).
  • Aligning of function call arguments in columns
  • Configurable indentation style
  • Set desired number of blank lines.
Integration:
STweep for Codesys also supports ABB automation Builder and e!Cockpit. See system requirements for the details.
Try Stweep now for free as 30 day demo!
More info at: www.STweep.com
  • CODESYS Development System V3.5.13.0 or higher
  • ABB Automation Builder 2.3 or higher
  • e!Cockpit 1.7.0.5 or higher
No restrictions
License activation optional on CODESYS Key or CODESYS Soft Key (part of CODESYS Development System)
Required accessories
Gerhard Barteling
support@stweep.com
Gerhard Barteling
Added
  • Support for STRUCT PERSISTENT, STRUCT CONSTANT, STRUCT NON_RETAIN, and VAR_GENERIC CONSTANT.
  • Support for setting line break style in CASE lists.
  • New formatter settings:
    • Line breaks in FOR statements.
    • Optional spaces between nested parentheses.
    • Blank lines at file start.
    • Indentation of the last comment before CASE or ELSE.
Changed
  • Expanded keyword conversion, more keywords now converted to uppercase.
  • Improved indentation handling for conditional and region pragmas.
Fixed
  • Incorrect formatting of generic constant variable declarations with multiple inputs.
  • Incorrect blank lines:
    • Before single line comments.
    • In nested statements surrounded by comments or pragmas.
    • In nested pragma IF cases.
    • At file start and end when only comments are present.
  • Incorrect indentation:
    • Pragmas at the end of STRUCT.
    • Trailing comments and pragmas at the end of CASE.
    • When using tabs.
  • Incorrect breaking of chained method calls.
  • Unneeded parser error when a semicolon is missing in a single statement.
  • Formatter exceptions in edge cases:
    • Semicolon after END_VAR.
    • {STweep.Disable} as last element in source.
    • Pragma keywords such as IF inside pragmas.
  • UI issue where "Parameter Indent DO" in FOR loop was not saved correctly.
2026-02-24
Added
  • Support for STRUCT PERSISTENT, STRUCT CONSTANT and STRUCT NON_RETAIN
  • Added settings to support line breaks in FOR statement
  • Added setting to make spaces between nested parentheses optional
  • Support for blank lines at file start
  • Support for STRUCT RETAIN
  • Support for access specifiers in a function declaration
Changed
  • Miscellaneous improvements and bug fixes
Fixed
  • Incorrect number of blank lines at file end if a code file did not contain a code part, but only comments
2024-01-16
Added
  • Support for single line if statements
    • Added setting: "Place simple if statements on a single line."
  • Improved formatting for IF statements.
    • Added setting: "Line break after IF"
    • Added setting: "Line break before THEN."
    • Added setting: "IF statement line break mode."
    • Added setting: "Indent THEN in if statement."
  • Improved formatting of implicit enums.
    • Added setting: "Line break after left parenthesis in implicit enum."
    • Added setting: "Line break before left parenthesis in implicit enum."
    • Added setting: "Line break before right parenthesis in implicit enum."
    • Added setting: "Maximum implicit enums on single Line."
    • Added setting: "Implicit enum parentheses style"
  • Search functionality in the settings editor
  • By clicking on a changed setting in the editor you navigate to this setting.
Changed
  • Signed package
  • In the settingsceditor the preview screen shows the formatted settings with the current (edited) settings.
  • Improved preview code.
Fixed
  • Incorrect loading of parameter line break after IF
  • Incorrect loading of parameter line break before THEN
  • Clicking on a changed setting did not always trigger the navigation to this canged setting.
  • Incorrect formatting exception when there was a semicolon after END_TYPE in a struct.
  • Improved handling when the user code contains parsing errors.
  • In some cases a single line comment on the first line was mistakenly aligned with an end of line comment on the second line.
  • Minimum number of blank lines was not always correctly taken into accoun, when updating number of blank lines before a statement.
  • Specified numer of blank lines after a code block was not always respected when the specified number of blank lines before the next code block was lower.
  • Formatting was not executed if code contained a ADR operator with a string literal as argument.
2022-10-19
Changed
  • Upgrade minimum installed .NET framework to 4.7.2.
Fixed
  • Parameter: >Spaces >Binary operators >Around assignment operator in function block initializer parameter assignment was not properly saved.
  • Possible formatting time out when formatting chained assign statements (A:=B:=C;). Exception only occurred when assignments are aligned in columns. And there is an assign statements in the previous line.
2022-05-25
Added
  • Option to align all members of an alignment in columns to tabs.
Changed
  • Miscellaneous improvements and bug fixes.
Fixed
  • Possible incorrect formatting of array initializer elements.
  • Incorrect formatting of property getter and setter declarations with an access specifier.
  • ncorrect formatting of a program declaration with access specifier.
  • Exception when formatting an empty array initializer.
  • Incorrect formatting of a variable declaration initializer with a REF= assignment.
  • Possible incorrect indenting of function call arguments when used in a multiline binary expression.
  • Incorrect formatting when empty single line comment ‘//’ was used.
  • Alignment of invocation call parameters were formatted with the incorrect settings when tabs are used.
  • Possible exception when align in columns with tabs and no spaces were used before alignment.
2022-01-31
Added
  • Support for conditional formatting with {STweep.Disable} and {STweep.Enable}.
  • Support for conditional formatting with (*STweep.Disable*) and (*STweep.Enable*).
  • Option to select indent style for align similar code in columns when tabs are used.
  • Settings editor shows number of unsaved settings and unsaved settings details if clicked.
Changed
  • Minor performance improvements.
  • Minor text updates.
Fixed
  • Rare cases of incorrect line length overflow handling when alignment of end of line comments in columns is used.
  • Possible “No solution found” exception when formatting structure initializers nested in an array initializer.
  • Possible incorrect line length overflow calculation when tabs are used.
  • Incorrect formatting when aligning in columns of assignment, number of blank lines before single line statement is 1 and number of blank lines after single line statement is 0.
  • Incorrect formatting when aligning in columns of address assignment, variable declaration and variable initializers when number of blank lines before single line declaration is 1 and number of blank lines after single line declaration is 0.
2021-05-10
Added
  • Option to align enum members in columns
  • Option to set line breaking mode for chained methods.
  • Aligning in columns for address assignments.
Changed
  • Chained variable access (A := B.C;) will now preferably break before the dot in case of an line length overflow. This was after the dot.
  • Set line breaks around ‘(‘ , ‘)’ , ‘[‘, ‘]’ are now placed if their construction is multiline. Before this was only the corresponding line break mode was set to “Break of long or multiline” or “Break always.”
  • Function block initializers for arrays are formatted according to the settings for functions block initializers. Before they where formatted according to the array initializers settings.
  • Minor UI Tweaks.
  • Minor translation updates.
Fixed
  • Incorrect formatting of statements containing ‘THIS’ without deference: ‘A(THIS);’
  • Incorrect formatting around statements like: ‘A REF= 0;’.
  • Incorrect formatting and possible exception of an array initializer with a trailing comma.
  • Incorrect formatting and possible exception of a structure initializer with a trailing comma.
  • Incorrect formatting and possible exception of a function block initializer with a trailing comma.
  • Incorrect formatting of array size specifier with a trailing comma.
  • Not working setting setting preview for array initializer indent mode.
2021-04-12
Added
  • Option to set parameter line break mode of structure initializers.
  • Option to place line break after '(' in structure initializer.
  • Option to place line break before ')' in structure initializer.
  • Option to place line break before '(' in structure initializer.
  • Option to set maximum number of parameters in structure initializer.
  • Option to set spaces before structure initializer parentheses.
  • Option to set spaces inside structure initializer parentheses.
  • Option to align structure initializer parameters in columns.
  • Option to align structure initializer parameter assignments in columns.
  • Option to set structure initializer parenthesis indentation style.
  • Option to set parameter line break mode of array initializers.
  • Option to place line break after '(' in array initializer.
  • Option to place line break before ')' in array initializer.
  • Option to place line break before '(' in array initializer.
  • Option to set maximum number of parameters in array initializer.
  • Option to set spaces before array initializer parentheses.
  • Option to set spaces inside array initializer parentheses.
  • Option to align array initializer parameters in columns.
  • Option to align array initializer parameter assignments in columns.
  • Option to set array initializer parenthesis indentation style.
  • Option to set spaces around argument assignment in function block and structure initializers.
  • Option to set parameter line break mode of function block initializers.
  • Option to place line break after '(' in function block initializer.
  • Option to place line break before ')' in function block initializer.
  • Option to place line break before '(' in function block initializer.
  • Option to set maximum number of parameters in function block initializer.
  • Option to set spaces before function block initializer parentheses.
  • Option to set spaces inside function block initializer parentheses.
  • Option to align function block initializer parameters in columns.
  • Option to align function block initializer parameter assignments in columns.
  • Option to set function block initializer parenthesis indentation style.
  • Changed
  • In case of a line length overflow line breaks are not placed directly after a semicolon anymore.
  • Improved line breaking after an assignment operator in case of a line overflow.
  • Minor updates in translations and UI.
  • Fixed
  • Setting "Blank lines after single line case" was not properly loaded in the UI.
  • Setting "Blank lines after multi line case" was not properly loaded in the UI.
  • Setting "Blank lines before single line declaration" was not properly loaded in the UI.
  • Incorrect formatting of a reference assign in a reference declaration : A : POINTER TO B REF= C;
  • Depending on the used settings the number of blank lines at the file end was not correctly set if the last element is a comment.
  • 2021-03-11
    Added
    • Option to place STRUCT keyword on a new line.
    • Option to indent else case in a case statement.
    • Option to add blank lines at the end of a code file.
    • Separate setting for Spaces around argument assignment.
    • "Documentation" command in menu bar.
    • "Report a bug or submit feedback" command in menu bar.
    Changed
    • Minor UI changes.
    • Updated/improved German translations.
    • Improved STweep menu structure.
    • STweep setting file format for improved handling
    • Improved code readability when wrapping functionblock declarations with EXTEND and IMPLEMENT.
    • Improved code readability when wrapping array initializer.
    • Improved code readability when wrapping struct initializer.
    Fixed
    • Incorrect formatting of function block initializers without arguments : VAR A : B(); END_VAR
    • Depending on the settings: if the first element in a file was a comment, the number of blank lines between file-start and the comment where not properly set.
    • Depending on the settings: if last element in a file was a comment the number of blank lines between file-end and the comment where not properly set.
    • Incorrect formatting of a statement similar to: 'THIS^.a REF= var;'
    • Depending on the settings: incorrect blank line inserted when multi line comment exceeded the line length limit.
    • Incorrect formatting of pointer to array declaration: "A:POINTER TO ARRAY[0..1] OF BOOL;".
    • Setting "Keep existing blank lines" was not respected at the end of a file.
    • Setting "Keep existing line breaks" was not respected at the end of a file.
    • Number of blank lines at start of file was not correctly set if first element is a comment.
    2021-02-09
    Added
    • Support for inline/local enum declaration. For example VAR A : (A,B,C); END_VAR
    Changed
    • A setting row is now selected when the containing setting is changed, this to show the preview.
    Fixed
    • Incorrect formatting of function block initializer. fb : fb(arg1,arg2) could lead to a missing parentheses after formatting.
    • Incorrect maintaining of blank lines between statements if there was a comment between the statements.
    • Possible exception when code to format has parsing errors (missing semicolon).
    • Possible exception when aligning long lines in columns.
    • Incorrect indentation of symbolic constants when used as case label.
    • No solution found bug when "Maximum invocation parameters on single line" was set to one and one not last argument had a end of line comment. For example: A(A,//Comment B);
    • Possible bug when "Maximum invocation parameters on single line" was set to "1", this could cause an exception.
    • Exception while formatting a reference declaration with an assignment. For example A : REFERENCE TO BOOL := A.A;
    2021-01-11
    Changed
    • Loading STweep formatting settings with an higher minor version is now allowed.
    • Improved handling for line length overflows in declaration code.
    Fixed
    • Unable to format interfaces and methods declared in an interface.
    • Incorrect license display.
    • Incorrect blank space by first statement in a statement list, if there was a preceding comment.
    • Bug where CODESYS sometimes gave an error message, because the abort request was checked from a non UI thread.
    • Incorrect functioning of the formatting time out check.
    • UI was not properly blocked while running the formatting task.
    Added
    • Support for line break after TYPE keyword.
    • Support for Import and export of settings.
    • Enhanced error message in case of any formatting exceptions.
    • Caret position is restored after formatting.
    • Optional indentation of derived data types in a 'TYPE' declaration.
    • Support for string size initialization with "(" and ")" for example A:STRING(20);
     2020-12-14
    Fixed
    • Possible licensing bug when licensed in softcontainer.
    Added
    • Support for chained method calls e.g.: 'A().B().C();'
    • Support for method and function calls which return a pointer. This can result in method calls like: 'A()^();'
    2020-11-23
    Fixed
    • Potential installation problem for Codesys SP15 and lower.
    Added
    • Support for ABB Automation Builder 2.3 and higher.
    • Support for e!Cockpit 1.7.0.5 and higher.
    2020-11-02
    Changed
    • Improved labels for blank line settings.
    • Improved label for blank lines around declarations category.
    Added
    • Previews in settings screen.
    2020-10-24
    Added
    • Support for German.
    Changed
    • Minor UI improvements.
    2020-10-18
    Fixed
    • Licensing bug
    2020-10-13
    Fixed
    • Missing PInvoke package on installation.
    • Incorrect capital use on manifest file extension.
    • Incorrect capital use on package file extension
    2020-10-13
    Initial Release
    2020-10-12
