AnyViz Cloud Adapter
Turns your PLC into an IoT gateway. AnyViz is probably the easiest way to monitor, operate and analyze machine and plant controls remotely.
With AnyViz Cloud Adapter, you can transform your existing PLCs into IoT gateways and connect your system to the AnyViz Cloud. Completely without complicated engineering tools and protocol configurations, you can immediately begin the online configuration of your Cloud HMI. The unique operating concept makes this possible without training. The innovative AnyViz communication protocol encrypts your data at the PLC level and is highly optimized thanks to push method. If the Internet connection fails, the data is temporarily stored on the controller.
Real-time process data visualization with just a few clicks
Process data recording and analyzing
Condition Monitoring
Remote control – from anywhere in the world
Communication between devices, beyond location borders
Access from any modern browser, whether workstation, tablet or smartphone
Note
For CODESYS versions prior to SP15, the Cloud Adapter version 1.7.7.2 is recommended. To get an older version, switch to the “All versions” tab.
Programming System | CODESYS Development System V3.5.6.0 |
Target System | CODESYS Control V3.5.6.0 |
Supported Platforms / Devices | For a list of tested controls, see http://www.anyviz.io |
Additional Requirements | AnyViz registration, see https://portal.anyviz.io |
Restrictions | |
Licensing | |
Required Accessory |
Mirasoft GmbH & Co. KG
Steingraben 13
97788 Neuendorf
Steingraben 13
97788 Neuendorf
