2-Axis MnJoystick
Der 2-Axis MnJoystick ist ein Visualisierungselement und kann zur Steuerung von Bewegungen in zwei Dimensionen verwendet werden.
000056
2-Axis MnJoystick is a visualisation element which is located in the Visu ToolBox under “MnControls Light”.
This joystick can be used to control movements in two dimensions.
Functional description
The joystick lever can be dragged within a given radius and returns following values:
  • X Value -> Deviation in the X direction from the center (-100 to 100, rest position = 0)
  • Y Value -> Deviation in the Y direction from the center (-100 to 100, rest position = 0)
  • Angle Value -> Angle to center ( 0 - 360 degree)
  • Radius Value -> Deviation from center (0 - 100)
Programming system
CODESYS Development System Version 3.5.4.0 or higher
Runtime system
CODESYS Control Version 3.5.4.0
Additional requirements
Required Accessory
exceet
exceet electronics AG
Riedstrasse 1
6343 Rotkreuz
Schweiz
+41 41 799 47 99
http://www.exceet-electronics.com/kontakt/
exceet
Riedstrasse 1
6343 Rotkreuz
Schweiz
