Pigeon for CODESYS Control
CODESYS Control for Pigeon allows users to program the Pigeon computers by using the CODESYS Development System.
2.0.0.0
000099
0,00 €
CODESYS Control for Pigeon contains support for the Pigeon computers family (RB100, RB300, RB100-CM3, RB300-CM3). Pigeon is a series of computers for use in control and automation systems. Pigeon computers have a rich set of inputs and outputs and a wide choice of interfaces (RS-232, RS-485, CAN, USB, 1-wire, HDMI). Interfaces, inputs and outputs are robust and meet requirements of EN 61326-1:2013 norm for industrial electromagnetic environments.
After installation of the CODESYS Control runtime system for Raspberry Pi and CODESYS Control for Pigeon, the Pigeon acts as a CODESYS controller, which can be engineered with the CODESYS Development System (V3). Device drivers for the following I/O are included:
  • Optoisolated Digital Inputs
  • Dry Contact Inputs
  • Digital Outputs
  • Analog Inputs
  • Analog Outputs
CODESYS Development System version 3.5.11.0 or higher
Target System
CODESYS Control version 3.5.11.0 or higher
Supported Platforms / Devices
Pigeon RB100, Pigeon RB100-CM3, Pigeon RB300, Pigeon RB300-CM3, Pigeon RB700
CODESYS Control for Raspberry Pi SL version 3.5.11.0 or higher
Required Accessory
KRISTECH Krzysztof Kajstura
Porzeczkowa 12
43-450 Ustron
Poland
support@kristech.eu
Porzeczkowa 12
43-450 Ustron
Poland
  • Pigeon RB700 support added
  • Support of CODESYS 3.5.16.70.
2022-04-26
First release in Store.
2017-08-16
