Description
With this library, you can start your IoT Project within minutes. You can send your data from the field to the cloud or request it. There is no 3rd Party software installation required. The communication is directly established with the Dweet Pro or Dweet Service; both are acting as a cloud gateway.
Each PLC needs to be registered as a “Thing”. So it’s possible to communicate with different “Things”, no matter if it’s a PLC or other device. Data is exchanged in the open-standard format JSON. So you can integrate the data easily to existing software products.
The product is coming along with a detailed documentation and a Quick-start guide (https://pfaendergmbh.atlassian.net/wiki/spaces/Dweet/overview). So you can start to use this library together with the dweet service within a really short time. The library can be tested without any fees!
Features and Use-Cases
Establish an industry secure connection between your PLC and the dweet Pro cloud service with TLS. The whole data connection from your PLC to the dweet service is completely encrypted. |
There are several options, to configure alerts directly in the cloud. Set Real-time notifications that keep you informed. It’s possible to set up E-Mail alerts directly from the Dweet Pro Cloud. Data can also be used to configure SMS or text-to-speech messages from another cloud providers. |
Store data up to one month, without the need of physical storage. |
Use cloud services to visualise your data or build it by your own. Connect quickly to freeboard.io and create a cloud visualisation within minutes. |
Communicate with devices in different locations. |
For data exchange, the open-standard JSON format is used. |
