UniPi Neuron for CODESYS SL
UniPi Neuron for CODESYS contains a package of driver support for the IO of the UniPi Neuron range of PLCs.
The product will be discontinued on 01. July 2020.
Version:
1.0.2.0
Artikelnummer:
2312000004
50,00 € zzgl. MwSt
  • ab 10 zu je 30,00 € und Sie sparen 40%
  • ab 20 zu je 20,00 € und Sie sparen 60%
UniPi Neuron for CODESYS SL contains support for the UniPi Neuron range of PLCs and expansion modules, specifically these models
•    UniPi Neuron L20x, L30x, L40x, L50x, L51x, M10x, M20x, M30x, M40x, M50x and S10x
•    UniPi Neuron Expansion modules xS10, xS30, xS40 and xS50
NOTE: Requires CODESYS for Raspberry Pi SL
einklappen
CODESYS Development System ≥ V3.5.12.0
Target System
CODESYS Control for Raspberry Pi SL ≥ V3.5.12.0 on UniPian Neuron OS ≥ 2018-1-16
Supported Platforms / Devices
  • The package can also be used on other CODESYS PLCs to communicate with the above Neuron devices.
  • CODESYS for Raspberry Pi SL
  • If the product is used for industrial purposes, it is the responsibility of the system manufacturer to ensure compliance with the necessary specifications.
  • The combination of Raspberry Pi and a CODESYS Runtime is primarily intended for test and teaching purposes.
  • The runtime system does not have real-time behavior. Its Jitter depends on many factors,especially on parallel executed Linux applications, and is ideally approximately 50 µs – with maximum values of approximately 400µs.
  • Activation on the CODESYS Soft Container (part of CODESYS for Raspberry Pi SL)
  • Optional: CODESYS Runtime Key
  • If there is no valid license, the software works for two hours without a functional restriction and then stops the application (demo).
Required Accessory
Versionshistorie
1.0.2.0
Supports CODESYS 3.5.14.0
2019-01-14
1.0.1.0
Cozens Software Solutions Limited
Amelia House, Crescent Road, Worthing, West Sussex, UK, BN11 1QR
support@cososo.co.uk
Weitere Produkte:
CODESYS for UniPi
CODESYS for UniPi
0,00 € zzgl. MwSt
Auf die Merkliste
Screenshots
