Web Client
The Web Client library allows for communication with a web server via HTTP or HTTPS. The library is appropriate for communication with a REST service.
The library “Web Client” is now part of the product IIoT Libraries SL and is no longer available as single product.
2111000025
The CODESYS software package includes a library with function blocks for communicating with a web server via HTTP or HTTPS.
  • The HTTP method GET requests data from a web server.
  • The HTTP methods POST and PUT submit data from the controller to a web server.
  • When using DELETE, data is deleted from a web server.
  • The HTTP method HEAD returns the HTTP header.
The HTTP header of a request can be extended without any restrictions. In addition, function blocks are included for HTTP basic authentication and authentication via OAuth (Version 1a and 2).
CODESYS Control V3.5.14.0
Workstation license
Reviews
Write Your Own Review
