Visu User Mgmt Dialogs Library
Source library containing the dialogs for the usermanagement available in the visualization.
000115
Use this library if you want to modify a visualization dialog to your needs, e.g. remove some buttons or adjust the layout.
Reviews
Write Your Own Review
