Task Manager
1.0.0.3
SKU
000004
Short descripton of the product…
Example:
The CODESYS Depictor is used for the flexible creation, illustration and animation of 3D models. For the creation of the 3D models, poses (geometrical relations / transformations) and elements (3D geometries) can be placed in a tree structure indicating the relation to each other. The pose properties (e.g. rotation angle) can be linked to CODESYS application variables, so that the whole 3D model can be animated.
CODESYS Development System Version 3.5.9.10 or higher
CODESYS Key
sales@codesys.com
Reviews
Write Your Own Review
