SNMP Library
This library makes it possible to read device information of printers, routers etc. via the SNMP protocol. The library provides function blocks to send and receive SNMP messages. The package contains the SNMP library and example applications.
The library “SNMP Library” is now part of the product IIoT Libraries SL and is no longer available as single product.
2111000005
Workstation License
Supported SNMP features:
  • SNMP GET: Request a value.
  • SNMP GET_NEXT: Request a value and get the OID from the next value.
  • SNMP Agent: Enables devices to request values from the control (agent).
  • SNMP TRAP: Send and receive TRAP/INFORM telegrams.
  • SNMP SET: Set values via SNMP
The package SNMPLibrary.package contains following components:
  • SNMPLibrary (Namespace: SNMP)
  • Project with example applications
  • CHM help
  • Product datasheet
CODESYS Development System V3.5.14.0 or higher
CODESYS Control V3.5.9.0 or higher
All
Supported SNMP versions: SNMP V1, SNMP V2c
Reviews
Write Your Own Review
