OpenCV for Raspberry Pi
3.5.11.0
SKU
000088
The OpenCV library for Raspberry Pi allows for the use of numerous algorithms of computer vision and image processing in an IEC implementation language.
The library allows for the use of OpenCV (see http://opencv.org/) with an IEC implementation language. Images taken by a camera, such as the RaspiCam or a USB webcam, can be analyzed and further processed on the PLC.
In addition to algorithms for object detection including various filters (for example, Canny, Gauss) and functions for camera calibration, the library contains functions for reading and saving images and other media files.
Scope
The library contains only functions and structures of the C API from OpenCV in Version 2.4.9. Altogether there are about 480 functions from OpenCV that can be used.
CODESYS Development System V3.5.11.0 or higher
CODESYS Control for Raspberry Pi V3.5.11.0 or higher
OpenCV 2.4.9.1
sales@codesys.com
Version Release Notes
Release Date
- 07.08.2018
Reviews
Write Your Own Review
