MQTT Client
The “MQTT Client” library allows for linking a CODESYS controller to an MQTT broker. Then messages can be sent and subscribed to based on topics.
The library “MQTT Client” is now part of the product IIoT Libraries SL and is no longer available as single product.
2111000027
Workstation License
MQTT (Message Queuing Telemetry Transport) is an open-source IoT protocol that allows for the transmission of telemetry data as messages between devices. Device communication always takes place by means of an MQTT broker (e.g. Mosquitto https://mosquitto.org/). Messages are sent and subscribed to based on topics. A topic corresponds to a path (e.g. device1/temperature). Subscribing to messages is done by specifying a topic filter. Wildcards are also permitted (+ for one level and # for multiple levels). The message format is not fixed, which means that a JSON string or any data structure can be transmitted.
With the “MQTT Client” library, messages can be sent from a CODESYS controller to an MQTT broker, and messages can be subscribed to based on topics.
Programming system
CODESYS Development System V3.5.14.0 or later
Runtime system
CODESYS Control V3.5.14.0 or later
Note: Use the “Device Reader” project for locating the functions supported by the PLC. The “Device Reader” project is available in the CODESYS Store free of charge.
Additional requirements
Required accessories
Reviews
Write Your Own Review
