Matrix Library
Define matrices of arbitrary dimensions. Execute basic operations (addition, multiplication, linear equations solving, inverting matrices and computing determinants) on matrices.
(A 7 day demo license is available for testing.)
1.0.0.1
2111000003
€275.00
Workstation License
The matrix library offers a data type to define matrices of arbitrary dimension and functions to perform basic operations on them.
CODESYS Development System Version 3.5.14.0 or higher
CODESYS Control Version 3.5.2.0
All
Version Release Notes
Release Date
Min. CODESYS version: 3.5.14.0
New Features:
  • Licensing without dongle
15.01.2019
Min. CODESYS version: 3.5.2.0
07.08.2018
