Mail Service
SKU
2111000001
With this library, emails can be sent, received, and deleted from one CODESYS controller.
The library “Mail Service” is now part of the product IIoT Libraries SL and is no longer available as single product.
This library contains function blocks for sending, receiving, and deleting emails by means of SMTP and POP3 protocols. Communication with the mail server can be established either encrypted (TLS) or unencrypted. A sample project demonstrates how to use the function blocks.
CODESYS Development System Version 3.5.14.0 or higher
CODESYS Control Version 3.5.14.0
Support of libraries SysSocket2, CmpTls, and CmpX509Cert
  • The mail server must support SMTP and POP3 protocols.
  • The mail server must support message IDs.
  • Establishing a connection via STARTTLS is not supported.
  • The maximum size of an email (maximum size of the send/receive buffer) is limited to 32,767 bytes.
Workstation license
sales@codesys.com
Reviews
Write Your Own Review
